Oggi è mar 17 nov 2026, 21:44
Scrivi un nuovo argomento Rispondi al messaggio Pagina 1 di 4   [ 58 messaggi ]
 Oggetto del messaggio: MWS su Linux
MessaggioInviato: mer 22 ago 2007, 12:20
Pare che un utente sia riuscito a far andare MWS su linux. Non posso provare personalmente, ma chi ha bisogno può provare e farmi sapere? Ecco qui le istruzioni.
Frozen-Solid ha scritto:
I use Mandriva 2007.1 Spring Edition, but it shouldn't be much different with other distros.
1) su to root
2) urpmi wine (or apt-get or whatever install thingy you do on whatever distro you use. The version I am running is 0.9.43)
3) exit (to go back to your normal logon)
4) mv ~/.wine ~/.winebackup (If you're daring or just don't care you can "rm -fdr ~/.wine" instead, but moving it is a "just in case" so you don't have to redo everything. Also, if you want to skip this step because of the hassle of reinstalling applications you use a lot feel free to try it, but I know it works with a fresh install.)
5) wget http://web.nickshanks.com/typography/co ... dale32.exe
6) wine andale32.exe
7) repeat steps 5-6 for each corefont (comic32.exe, impact32.exe, verdan32.exe, arial32.exe, courie32.exe, times32.exe, webdin32.exe, arialb32.exe, georgi32.exe, trebuc32.exe)
8) wget http://www.magicworkstation.com/download/mws094f.exe
9) wine mws094f.exe
10) wget http://mwsgames.com/download/mtg_gamepack.exe
11) wine mtg_gamepack.exe
12) Either click "Autoupdate MWS" in your applications menu or cd to your install directory and run "wine Autoupdater.exe"
13) Either click "Magic Workstation" in your applications menu or cd to your install directory and run "wine MagicWorkstation.exe"
Optional steps (Goblin Hero Goodness)
14) After it's loaded the updates, close MWS
15) wget http://slightlymagic.net/download/MasterBase.rar
16) unrar x MasterBase.rar <path to install directory>
17) wget http://slightlymagic.net/download/NewMagicTheme.rar (Replace with OldMagicTheme.rar if you're an old fogey who still can't get over that WotC could POSSIBLY imagine changing how your beautiful cards look)
18) unrar x NewMagicTheme.rar <path to themes directory>
19) wget http://slightlymagic.net/download/MWSPA.rar
20) unrar x MWSPA.rar <path to install directory>
21) If you haven't yet, cd to the install directory and run wine MWSPA.exe
22) You can now rm anything that you downloaded with wget.
You now *should* have a fully functional MWS Library and MWS Play. Both can be run via command line (wine MagicWorkstation.exe) or via the applications menu.
EDIT 3/12/2010:
Aggiungo questo post di Milos che sembra aver risolto la quasi totalità dei problemi.
Milos ha scritto:
Buon Giorno a tutti Cari magicchiani !!!
Questa è un guida completa per chi come me utilizza il il pinguino e non vuole abbandonare magic Work Station !!!
Mi sono rotto di leggere in giro pezzi e soluzioni... quindi ecco una guida semplice e precisa...
Allora intanto per giocare a MWS abbiamo bisogno di due cose installate.
Linux Ubuntu 10.10 (attualmente la versione più completa e diffusa del pinguino) e Wine installato.
Per chi non lo conosce wine è un programma che permette di far girare i programmi di win su linux. Non tutti naturalmente ;)
Si installa wine in due modi (molti sistemi ormai gia lo danno di base)
Installare Wine tramite gestore di programmi è semplice; si apre da applicazioni il gestore di pacchetti si scrive wine e si installa ! altrimenti da terminale si da questo comando
Sudo apt-get install wine
e dopo aver inserito i privilegi da root parte l'installazione.
Una volta installato Wine, dobbiamo abilitare e attivare dei trick che causano come molti utenti sanno problemi con le carte con i caratteli al contrario e le immagini storte ;)
Allora questa è la parte più interessante.
Aprite un documento semplice bianco e copiateci dentro lo script che trovate dentro questo sito. TUTTO !
http://www.kegel.com/wine/winetricks
Una volta copiato questo script, salvate il documento come eseguibile ovvero file salva col nome e sotto spuntate il date come eseguibile.
Cliccate sopra l'icona del documento che avrà cambiato icona e mettete esegui nel terminale.
Compariranno tutti i programmi base di windows a noi ci interessa di installare e spuntare due soli di quei programmi.
corefonts
gdiplus
Spuntateli e installateli
Successivamente potete installare MWS e giocarci tranquillamente senza più problemi di sistema o di errori (l'unica cosa che ho notato è che non lancia il dado :( )
Ps. Se wine non vi va lanciare gli eseguibili dicendo che non è sicuro andate su applicazioni wine installa o disintalla programmi
e fate installa programma dal menù che compare scegliendo il percorso dell'exe salvato sul pc.
Spero che questa guida sia utile a molti ! Perchè il pinguino va diffuso tanto quanto Magic !!!
Un Abbraccio a tutti !!!!!
Milos
Faccio inoltre presente che per il problema del dado pare che (misteriosamente) se si modifica per poi risettare a 20 il numero delle
facce, il lancio di dado funzioni (!).
EDIT 17/11/2012
Come suggerisce Biareus:
Era più facile del previsto: quello che ha scritto Milos è effettivamente giusto (cioè installare gdiplus e i font), ma non c'è nessun bisogno di fare quei giri che descrive lui. Almeno io (ma penso chiunque installi le ultime versioni di wine) si ritrova con winetricks già di default, in cui appunto si trovano i due pacchetti da scaricare.
Ultima modifica di Malhavoc il dom 18 nov 2012, 3:11, modificato 4 volte in totale.
MessaggioInviato: mer 22 ago 2007, 14:02
A me va con wine senza problemi da diverso tempo (ubuntu).
Cerco:
Mox Sapphire Alpha
Il Mio Cerco:
http://www.tipo1.it/forum/viewtopic.php?t=16963
MessaggioInviato: mer 22 ago 2007, 14:34
Hai provato se va anche il MWSHost?
http://www.magicworkstation.com/download/MWSHost.zip
..è quello che viene usato anche sul server ufficiale, permette di hostare più partite sul computer locale.
MessaggioInviato: ven 24 ago 2007, 13:01
Nessuno ha idea se può funzionare sulla Suse 10.2 con grafica Gnome??? :D
mrincubus ha scritto:
MessaggioInviato: dom 26 ago 2007, 1:46
che divide per zero
Gnome, KDE o altro fa poca differenza: basta che la versione di Wine sia la stessa, e funzionerà ^_^
Chiedete e vi sarà domandato
MessaggioInviato: ven 31 ago 2007, 13:11
speranze di vederlo per mac os x?
MessaggioInviato: ven 31 ago 2007, 13:18
Non ho notizie certe, ma dai una letta qui:
http://www.magi-soft.com/forum/viewtopic.php?p=42005
Consigliano di provare ad usare DarWine o Crossover.
Ultima modifica di Malhavoc il ven 31 ago 2007, 13:32, modificato 1 volta in totale.
MessaggioInviato: ven 31 ago 2007, 13:21
Per ora devi accontentarti di usarlo tramite Virtual Machine che emuli XP [Parallel Desktop ad esempio], anche se tale escamotage ciuccia infinite risorse - passo da 1500 rpm medi di ventola a 6500 [!!!] quando sono costretto a usare un'applicazione windows -.-
MessaggioInviato: ven 31 ago 2007, 18:03
Con crossover ho gia provato e non funziona.
Con parallel lasciamo perdere, a parte la lentezza dell'intero sistema, avere un tavolo da gioco vedibile è un pò un sogno.
Per ora mi sono adeguato facendo il riavvio con win vista, ma se non fosse per mws userei solo osx, e usare win solo per mws mi sembra un po sprecato.
Cmq continuo a sperare in un eventuale sviluppo, anche se da qualche parte avevo letto che poichè il programma viene sviluppato in Russia, e in Russia la quantità di Apple che gira rasenta lo zero, rasenta lo zero anche la possibilità di vedere mws su osx. Spero di sbagliare.
Teniamoci in contatto per eventuali novità.
P
MessaggioInviato: ven 31 ago 2007, 18:12
P
Ni. Se non sbaglio lo sviluppatore principale ha comprato un Mac un po' di tempo fa. Tuttavia la MWS è sviluppata in Delphi, e convertire il tutto su Mac mi ricordo aveva detto richiederebbe non so che software/librerie che costa davvero un po' troppo per il numero di potenziali utenti Mac.
In realtà è in fase di sviluppo (da tempo immemore) una nuova versione della MWS riscritta da zero e programmata in C#, che grazie al .NETFramework dovrebbe cmq essere un po' più portabile (entro certi limiti). Tuttavia la data di uscita è impossibile da ipotizzare.
MessaggioInviato: dom 2 dic 2007, 21:55
This is release 0.9.50 of Wine, a free implementation of Windows on Unix.
What's new in this release:
- Completed I/O completion.
- Improved user credentials management, including Mac Keychain support.
- More Valgrinding.
- Lots of bug fixes.
MWSHost.exe now runs under wine and as far as I can tell has no issues.
MessaggioInviato: lun 3 dic 2007, 19:13
Per culUbuntu si sa niente? :mrgreen:
pdL ha scritto:
MessaggioInviato: mer 5 dic 2007, 0:58
che divide per zero
Gira tanto MWS quanto MWSHost, direi. Provasti?
MessaggioInviato: mer 5 dic 2007, 1:10
Il problema è che io ho già istallato Mws sulla partizione Win. Ora dovrei reistallarla tramite Wine?
MessaggioInviato: gio 6 dic 2007, 0:03
che divide per zero
Puoi seguire le istruzioni di Malhavoc per farlo girare da chiavetta, ma rifacendo tutto il discorso sotto Linux. A quel punto fai partire l'eseguibile direttamente dalla partizione Win (che immagino avrai montato in qualche modo sotto Linux).
