Oggi è ven 14 ago 2026, 22:48
 Oggetto del messaggio: Problema con l'apertura di MWS (irrisolto)
MessaggioInviato: gio 29 apr 2010, 18:43
Premetto che con l'utilizzo del pc sono abbastanza asino, comunque penso che almeno l'installazione di mws l'abbia fatta giusta, ma passiamo al problema.
Ho deciso scaricare mws per provarla anch'io tuttavia arrivato al punto due della guida, quindi subito dopo l'installazione, ho provato ad aprirla e mi compare una finestra con nessun pulsante e che non mi permette in alcun modo di interagire con il programma, nemmeno di chiuderlo.
Riporto qua il testo della finestra:
Please register
Register your copy today with a 20% discount (offert valid until version 1.0 release)
Most of Magic Workstation's features are available in the shareware version. However some are limited or
restricted. Here is information about what is available in the Registered version of Magic Workstation that is not
available in the Shareware/Unregistered version.
What registering will get you:
* A registration code emailed to you.
* Your code will remove the shareware reminder and banner windows.
* You will also gain access to the registered-only features, such as:
* You can create your own cardsets without limitation (30 cards limit in unregistered version);
* You can test your decks without using "mirror-match" mode;
* You can print more than one page of deck listing and/or proxy card listing;
* Eliminates reminder labels in any output documents (in export menu);
* You can do personal feature request and it will be implemented in next versions;
* You can view your opponent's photo or avatar;
* You gain full access to card ranking management system;
* You gain access to the private part of our forum;
* You gain a personal directory on our server to host your decks and/or misc. info;
* You gain personal support by e-mail;
* A warm, fuzzy feeling that you did the right thing. Without your support, we can't keep adding new features to
Magic Workstation, can't have support people to help you if you have problems, etc.
Your support will help us to develop new versions of MWS and we plan add many powerful features such as:
* Dedicated server for hosting tournaments and ranking system;
* Automated rule checking;
* Voice chat during network game;
* Draft systems;
* ... and many more useful features;
Thanks for your support!
Ho semplicemente installato il programma senza aggiungere le espansioni, immagini etc.etc., qualcuno può aiutarmi a risolvere questo inconveniente?
Se non mi fossi spiegato abastanza chiedete pure.
Grazie mille in anticipo!!
P.s. ho cercato in giro situazioni simili ma non ho trovato niente.
Ultima modifica di ilPissa il lun 3 mag 2010, 19:17, modificato 1 volta in totale.
MessaggioInviato: gio 29 apr 2010, 18:46
Non è un problema , se non hai la versione registrata ogni volta che apri MWS, ti apre quella finestrella lì. Basta aspettare comunque 5 secondi e cliccare su ok in basso a sinistra della finestrella , e dopo puoi usare mws tranquillamente.
MessaggioInviato: gio 29 apr 2010, 18:52
Il problema è che non mi compare l'ok :'( .
MessaggioInviato: gio 29 apr 2010, 18:58
Stranissimo.
Teoricamente dovrebbe uscirti una cosa del genere.
http://img32.imageshack.us/img32/677/snapshot16l.png
Di più non so come aiutarti.
MessaggioInviato: gio 29 apr 2010, 19:03
Mi mancano quei tre tasti alla fine, all'inizo pensavo fossero nascosti, ho provato ad allargare la finestra e cose del genere, ma niente.
