Oggi è ven 8 mag 2026, 10:01
 Oggetto del messaggio: Tornei ufficiali con carte alfa
MessaggioInviato: sab 17 gen 2009, 12:52
è possibile partecipare regolarmente a un torneo con alcune alfa? parteciperei con bustine dal dorso opaco.
Grazie della risposta
 Oggetto del messaggio: Re: Tornei ufficiali con carte alfa
MessaggioInviato: sab 17 gen 2009, 14:12
Per un torneo T1 ecco cosa dicono....
Updated December 20, 2008
Constructed decks must contain a minimum of sixty cards. There is no maximum deck size; however, you must be able to shuffle your deck with no assistance. If a player wishes to use a sideboard, it must contain exactly fifteen cards.
With the exception of basic land cards, a player’s combined deck and sideboard may not contain more than four of any individual card, counted by its English card title equivalent. All cards named Plains, Island, Swamp, Mountain, and Forest are basic. (The five Ice Age snow-covered lands -- Snow-Covered Plains, Snow-Covered Island, Snow-Covered Swamp, Snow-Covered Mountain, and Snow-Covered Forest -- are also basic lands. Note that snow-covered lands are permitted only in formats that allow the Ice Age set to be used.)
The following cards are banned in Vintage tournaments:
Any ante card
Chaos Orb
Falling Star
Shahrazad
The following cards are restricted* in Vintage tournaments
Ancestral Recall
Balance
Black Lotus
Brainstorm
Burning Wish
Channel
Crop Rotation
Demonic Consultation
Demonic Tutor
Enlightened Tutor
Entomb
Fact or Fiction
Fastbond
Flash
Frantic Search
Gifts Ungiven
Grim Monolith
Gush
Imperial Seal
Library of Alexandria
Lion’s Eye Diamond
Lotus Petal
Mana Crypt
Mana Vault
Memory Jar
Merchant Scroll
Mind’s Desire
Mox Emerald
Mox Jet
Mox Pearl
Mox Ruby
Mox Sapphire
Mystical Tutor
Necropotence
Ponder
Regrowth
Sol Ring
Strip Mine
Time Vault
Time Walk
Timetwister
Tinker
Tolarian Academy
Trinisphere
Vampiric Tutor
Wheel of Fortune
Windfall
Yawgmoth’s Bargain
Yawgmoth’s Will
Official information about Constructed formats and the Vintage format can be found in the Magic: The Gathering Floor Rules.
*Restricted Card: A card that is limited by the DCI to one per deck in the indicated format. For example, the card Black Lotus is restricted in DCI-sanctioned Vintage Magic tournaments. This means that only one Black Lotus is allowed per deck, including sideboard, in the Vintage format.
MessaggioInviato: sab 17 gen 2009, 14:19
e belin questo lo so, ma so anche che anni fà girava la voce che le alfa potevano essere riconoscibili per i loro bordi arrotondati.
Nessun pazzo lo fa ma questa regola esisteva per evitare un palese vantaggio se teoricamente giocassi senza bustine.
Mi chiedo solo se la regola a sto punto sia mai esistita o se esista ancora, oltretutto non è raro trovare la stessa carta con una quotazione leggermente superiore per la versione beta nonostante la tiratura sia 3:1
MessaggioInviato: sab 17 gen 2009, 18:59
La regola esiste ancora:
Magic Floor Rules ha scritto:
102. Authorized Cards
Alpha cards (cards from the first print run of the core set) may be used in decks containing non-Alpha cards only if all cards are placed in completely opaque sleeves and only if the sleeves could not be considered marked. If sleeves are not used, Alpha cards may be used only in decks that consist exclusively of Alpha cards.
Quindi se giochi con bustine dal dorso opaco (e oppiamente le bustine non sono segnate), vai tranquillo. ;)
MessaggioInviato: dom 18 gen 2009, 20:37
unico appunto: occhio alle bustine sottili un po' usurate:
dopo un pò di uso su alcune buste si può vedere "l'impronta" del retro delle carte
se prendi delle buste più robuste invece non ci sono rischi (tra l'altro vorrei vedere a giocare care alpha con bustine ultraleggere o sottili... sarebbe da pazzi)
MessaggioInviato: lun 19 gen 2009, 4:10
perfetto grazie!
