Oggi è gio 23 apr 2026, 12:53
 Oggetto del messaggio: [News] Marzo 2008 DCI Banned and Restricted List Update
MessaggioInviato: sab 1 mar 2008, 3:24
Direttamente dal sito DCI:
March 1 2008 DCI Banned and Restricted List Announcement -- Magic: The Gathering
Announcement Date: March 1, 2008
Magic Online Effective Date: Wednesday, March 26, 2008
(after the regularly scheduled Wednesday downtime)
DCI Floor Rule Change Announcement: Extended Rotation
The scheduled October 2008 rotation of the Extended format, as listed in the Magic Floor Rules, has changed. Following the release of the set codenamed "Rock", the following sets will be leaving the Extended format: Invasion, Planeshift, Apocalypse, Odyssey, Torment, Judgment, and Seventh Edition. The rotation previously listed in the floor rules also included Onslaught, Legions™, and Scourge. These three sets are now scheduled to leave Extended in 2009. One years' worth of blocks will leave Extended with every fall Magic release, syncing up Extended rotation with Standard rotation.
For more information about this change and the reasoning behind it, see Devin Low's Latest Developments article for Friday, March 7 on magicthegathering.com.
Standard, Vintage, Legacy, Lorwyn Block Constructed, Two-Headed Giant Constructed
No changes
Online Formats:
Rule Set: Commander FFA Rules
Commander FFA is a rule set for Magic Online players, much like Two-Headed Giant or Emperor. It is based on the offline Elder Dragon Highlander rule set, which you can read more about here. Commander FFA is a variant of multiplayer free-for-all and can only be played with the 100 Card Singleton format described below.
In Commander rules, each player has a starting life total of 40 rather than the usual 20. A player chooses a legendary creature, called a commander, and builds a deck including his or her commander. Only colorless cards and cards of the commander's color(s) may be included in the deck. Note that split cards and hybrid cards count as all of their colors. Aside from these deck building restrictions, your commander works differently from other cards in-game as identified below.
Before the game begins, each player removes his or her commander from the game. If a player's commander would go to the graveyard from anywhere, he or she may choose to remove it from the game instead. A player may play his or her commander from the removed from the game zone for its normal costs plus an additional 2 for each previous time it has been played this way. If a player would add mana to his or her mana pool that's a color his or her commander is not, colorless mana is added instead. In addition to the normal Magic loss conditions, if a player is dealt 21 points of combat damage from a single commander over the course of the game, that player loses the game.
Commanders are immune from the "legend rule," so don't worry if your commander is the same as someone else's.
Format: 100 Card Singleton
100 Card Singleton is a Magic Online format in which each player's deck must contain exactly 100 cards—no more, and no less—and no two cards in a deck can share a name unless they're basic lands. 100 Card Singleton doesn't require you to use Commander rules to play it, but it's designed to work with Commander rules and the banned list is created with commander rules is mind.
The current banned list for 100 Card Singleton is as follows:
Biorhythm is banned.
Coalition Victory is banned.
Crucible of Worlds is banned.
Gleemox is banned.
Panoptic Mirror is banned.
Riftsweeper is banned.
Rune-Tail, Kitsune Ascendant is banned.
Sway of the Stars is banned.
Test of Endurance is banned.
Upheaval is banned.
Worldgorger Dragon is banned.
Effective Wednesday, March 26, 2008, Kokusho, the Evening Star is banned.
Vanguard Avatar Changes
Seven Vanguard avatars will receive adjustments to their starting hand and/or life total modifiers in order to promote the continued health of the Vanguard format. The following avatars will be changed, effective Wednesday, March 26, 2008:
Mirri the Cursed
Heartwood Storyteller
Dakkon Blackblade
Jhoira of the Ghitu
Ashling the Pilgrim
Maro
Royal Assassin
For the specific avatar changes and reasoning behind them, see Ken Nagle's article on the Magic Online page. For a complete list of Vanguard avatars and their abilities, click here.
Tribal Wars, Freeform, Classic, Singleton, Prismatic
No changes
For the complete list of all banned and restricted cards by format, click here.
MessaggioInviato: sab 1 mar 2008, 4:26
Quindi a Ottobre assalto non lascerà l'esteso lasciando giocabili le fetch? molto interessante.
Non mi è chiaro però quando dice che assalto lascerà l'esteso nel 2009...dal momento che l'estate 2009 sarà quella in cui esce l'undicesima edizione si potrebbe congetturare che in 11esima si ristamperanno le fetch... 7-)
 Oggetto del messaggio: Re: [News] Marzo 2008 DCI Banned and Restricted List Update
MessaggioInviato: sab 1 mar 2008, 10:21
in sostanza dice che a ottobre 2008 usciranno dall'esteso i set fino al blocco assalto (escluso) e che ogni ottobre successivo l'esteso ruotera' di un blocco, come succede con lo standard... che brutto...
Edi1986 ha scritto:
 Oggetto del messaggio: a
MessaggioInviato: sab 1 mar 2008, 10:31
FIGA SONO DIO. che sculata ahahha!
Marotta ahahhaha non potrai andare a NIZZA.
PS: la mia figa sempre piu UPPPP ho comprato del tipo 200 fetch.
PRO TOUR... ARRRIVOOOOO! :-D
MessaggioInviato: sab 1 mar 2008, 11:46
maledisiun... ma scenderanno mai di prezzo ste fetch? 8-*
A far mangiare i denti alle Gente noi del miracolus ci mettiamo poco
MessaggioInviato: sab 1 mar 2008, 11:50
...che stronzata inutile...
quindi che ruota? pernice, vindicate, lavamante, icoride, duress-therapy...e basta? sinceramente al momento non mi viene in mente nient'altro di utilizzato che se ne andrà con quel blocco...a parte le boiate per madness ma chi lo usa più quel mazzo?
EDIT: ah, dimenticavo counterspell!
MessaggioInviato: sab 1 mar 2008, 14:13
aggiungi molta roba di rock...
comunque bella merda... prima con la rotazione da tre cambiavano tutti i mazzi ora avremo a vita sempre i soliti...
mamma mia che idioti...
MessaggioInviato: sab 1 mar 2008, 15:07
...e fu cosi che si liberarono della possibile crescita del legacy dovuta alla rotazione che avrebbe rivoluzionato l'esteso...
MessaggioInviato: sab 1 mar 2008, 15:55
Cumunque la wizard ha dinuovo evitato di fare cambiamenti per noi e il meta rimane sempre lo stesso X-D X-D
MessaggioInviato: sab 1 mar 2008, 16:14
Congettura molto interessante e forse realistica, ma può anche darsi che in un blocco successivo vengano stampate le fetch dei colori "nemici", in modo che non escano dall'esteso e continuino a stampare nel set base le painlands.
A dir la verità, non credo che questo cambierà la percezione del Legacy, in quanto da Ottobre in poi esteso ruoterà ogni anno e fornirà carte più recenti, non andrà a ledere sui formati Eternal... :-x
Wizard ha scritto:
BIMBO ha scritto:
BOOOOOOOOM!
MessaggioInviato: sab 1 mar 2008, 17:00
Io invece la penso cm Kikkofrio. A mio parere cn l'abbandono delle fetch dall'EXT molti giocatori si sarebbero avvicinati di più al legacy 7-) ma questo mi sembra un segnale chiaro della wizzy che vuole continuare a puntare tantissimo sull'EXT :-x
MessaggioInviato: sab 1 mar 2008, 20:46
di che ti lamenti , te puoi continuare a giocare i tuoi goblin per un altro anno ancora !! :-D
MessaggioInviato: sab 1 mar 2008, 21:44
beh invece imho:
1) ruotare un set all'anno è meglio perchè ti permette di pianificare meglio e soprattutto di non trovarti con Xmila carte inutili tutte insieme;
2) chi gioca extended ai ptq non comincia a giocare legacy perchè legacy non qualifica ai pt;
3) dato che standard la rotazione è così, meglio allinearsi anche con l'extended per chiarezza.
David suspended Ancestral Visions off his first Island. "We know who's winning this game" replied Cheon.
MessaggioInviato: sab 1 mar 2008, 21:50
...oltretutto ancora un anno di RG a manetta e ancora un anno di tarmogoyf sgravato.
bello è bello, ma senza la terra di fisso al cimitero inizia ad essere ridimensionato.
ho paura che sta cartaccia salirà a 150 secchi il set.
