Oggi è mar 5 mag 2026, 23:18
Scrivi un nuovo argomento Forum bloccato Pagina 10 di 14   [ 208 messaggi ]
Vai alla pagina Precedente  1 ... 7, 8, 9, 10, 11, 12, 13, 14  Prossimo
MessaggioInviato: dom 14 ago 2011, 1:39
A) tritoni e gobbi fanno cagare
B) la wizard vuole bene a chi piace piegare tante volte le figurine per vincere
C) anche il prezzo del tarmo sta salendo lol
The Source ha scritto:
Gentlemen -
I know that everyone is excited about the new format. And I know that there's this shiny (relatively) empty forum to post in. But one of the things that makes me proud to post at the Source is the quality of the posts here. And while this is not a DtB/LMF or Established forum, I'm seeing a lot of posts that read:
"Hey, this is my idea for a deck. I have never actually played a game of Modern or done any research on the format, but I think this would make a good place to start because [insert poorly reasoned statement here]. This list is not tuned or tested and I haven't even counted it to make sure it's 75 cards, but I would like someone else to play with it and fix it for me."
We're better than that guys. The forum will still be here tomorrow after you've done some bare minimum testing to make sure that your deck isn't a pile of dogshit. Don't start a thread that's just going to die an ignoble death in the next 24 hours because you had temporary diarhea of the fingers. Pro tip: if you can't put a sideboard together for the deck, don't post it. You need to know what your deck is weak to before you start trying to improve it. Adding Firespouts when you already curbstomp Zoo is dumb, but if you don't know that you already beat Zoo, you may just try it. Then you look like an asshole.
As a corollary, there are several existing forums and results from 1 tournament that can be used as research. So when you say "I think Modern will look like 'x' because cards 'y' and 'z' are just killer", if you haven't spent 15 minutes researching to make sure that cards y and z actually impact the format, you look like an asshole. Tarmogoyf is not the best card in this format. If I read you saying that it is, I immediately ignore anything further that you've written because you obviously haven't done your homework. If you say that Hive Mind is the best card in the format, well then I may disagree with you, but at least I'll know that you know your shit and that your opinion is to be respected.
Also, you can't just port your favorite deck from Standard/Legacy/previous Extended/whatever. The format operates differently. While there are occasionally successful ports from one format to another, these are done by people who understand both formats and see an opportunity for a single strategy to function well against the field in both. Just as Ancient Tomb and City of Traitors are not good enough replacements for Mishra's Workshop (and Thorn isn't good at all) to make MUD function in Legacy, your whatever deck is not going to function in Modern. While there are parallel decks in the format, they are not straight ports. If you just swap in Lightning Helix for Chain Lightning from your Legacy Zoo and play it in Modern, you will be playing a suboptimal Zoo deck. If you do this, anyone that knows the format will look at you and think you're an asshole.
In conclusion, please don't be an asshole. Unless you're IBA; then people expect you to be an asshole.
Thanks,
Mike
Ditto.
MessaggioInviato: dom 14 ago 2011, 2:44
io ripeto che in questo forum dovrebbero esserci i tasti "like" e "unlike",così io non avrei dovuto scrivere questo commento monoriga,probabilmente prendere un warning e avere già milioni di LIKE appena finito di postare (dato che ormai l ho fatto). Il tutto per dire che apprezzo la citazione di the source..
best player t3 by far
MessaggioInviato: dom 14 ago 2011, 5:04
Da, i tuoi post sono l'unico motivo per cui alle 5 di mattina guardo Tipo1! :-D
MessaggioInviato: dom 14 ago 2011, 10:44
io ripeto che in questo forum dovrebbero esserci i tasti "like" e "unlike",così io non avrei dovuto scrivere questo commento monoriga,probabilmente prendere un warning e avere già milioni di LIKE appena finito di postare (dato che ormai l ho fatto). Il tutto per dire che apprezzo la citazione di the source...
Like ;-*
MessaggioInviato: dom 14 ago 2011, 10:58
se pensi che la maggior parte di quelli che son felici dell'uscita del modern soffrono del fatto che ora in legacy ci sono troppe combo per ritardati, dovrebbe darti un messaggio sul fatto che piegare le figurine non piace solo alla wizard, è una cosa che si chiama costruire il proprio gioco.
Ultimamente stanno uscendo in legacy 2 combo particolari che al di là di tritoni, son quasi inattaccabili dagli altri deck.
La prima Show&tel/hive mind, ha un hate specifico [card]grazia dell'angelo[/card] che è ridicolo, e hate secondari che sono counter e discard effect, in pratica se non giochi bianco mettendo 3/4 morchie in side, gli altri hate effect son ridicoli, in quanto spesso il deck ha più protezioni di tutti gli altri 4 fow4 patti blu 4 mm.
Altra combo per down è reanimator attuale con jinjiraxias, ragazzi finalmente la wizard c'è riuscita, con nuova phyrexia sono riuscita a stampare i mostri forti che non richiedono alcuna scelta, sono 3 ma in reanimator se ne giocano solo 2, in quanto il 3° è un overkill.
ordine delle giocate, mettere al cesso jinraxias, rianimare jinraxias, passare subito, pescare 7, se l'oppo fa spigo a fine turno si pesca lo stesso 7, se l'oppo attiva karakass a fine turno si pesca lo stesso 7, poi se è stato rimbalzato scartare ancora jiraxias e gli altri ciccioni (in più oltre le 7 carte in mano) se jiraxias è ancora in gioco l'oppo è morto in quanto nel draw7 saranno usciti almeno un mm e una fow?, quindi ricapitolando jiraxias per pescare e scartare e con un pò di fortuna resettare la mano dell'opponent.
Elesh norn, se si gioca contro aggro si rianima lei, risultato? solo progenitus e reliquario nel meta attuale possono attaccare.
in pratica Iona prima era IL mostro da rianimare perchè aveva un abilità fortissima, ma richiedeva UNA scelta, ora chi gioca reanimator mentre pulisce la bava alla bocca ha finalmente il modo di vincere, non rischia più di sbagliare.
Il modern si prospetta un formato molto aggro per via della banning list a senso unico vs controllo e combo, e sicuramente ci farò un giro, ovviamente se la wiz farà la stessa cosa del tipo1 e smetterà di fare banning list per il legacy, per poter giocare senza che uno spento faccia" gioco queste 2 carte ho vinto" , si passerà al modern, a piegare le figurine, per chi vuole giocare combo come dragon storm e zanne e unghie in modern ci sono gaddock, scartini, asportare effect sia a 4 che a 1 e fiala che permette di aggirare molti casting cost per race veloci.
MessaggioInviato: dom 14 ago 2011, 12:09
basterà fare spiga su jin prima che l'avversario entri nella sottofase finale...o sbaglio... :'|
MessaggioInviato: dom 14 ago 2011, 13:01
4 spighe vs 4fow 4 mm 3 daze good luck
MessaggioInviato: dom 14 ago 2011, 13:15
Gia perchè io i miei counter li saido out
MessaggioInviato: dom 14 ago 2011, 13:16
Sarebbe stato più onesto ammettere di aver preso una cantonata su Jin-Gitaxias.
Ad ogni modo torniamo in topic (anche se prevedo un lock a breve)
MessaggioInviato: dom 14 ago 2011, 13:39
Loky, ma ci hai mai giocato contro ad hive mind? è forse il mazzo che si chioda più facilmente di tutti...e anche reanimator non mi sembra sto grande esempio di fluidità di gioco...e poi, quotando l'araldo, jin jitaxias lo puoi benissimo spigare prima che faccia la sua abiltià.
Il legacy, a mio parere, è un formato bello, vario, equilibrato (sicuramente era più equilbrato prima di MM, quella forse è stata la carta che lo ha un pò rovinato).
Onestamente, questo modern non mi attira, dato che dredge non si può montare :-D :-D :-D
MessaggioInviato: dom 14 ago 2011, 13:47
OT:
il legacy attualmente non è equilibrato, in quanto i combo attualmente occupano una gran fetta delle top8, di controlli se ne vedono pochi e gli aggro le buscano.
prima di misstep maverik era IL tier e molte partite venivano decise da un banale terra-fiala. misstep permette a tutti i mazzi di avere una protezione slim a carte sbroccate o partenze devastanti (che solo certi mazzi possono permettersi, e senza misstep come li batti?). QUESTO rende il gioco + equilibrato. (in termini di risposte, il meta è un'altro discorso)
vincent86 ha scritto:
2x Breeding Pool = shockland
3x Forest = terra base
5x Island = terra base
MessaggioInviato: dom 14 ago 2011, 13:51
Angel's grace sarà pure ridicolo come hate, ma hive mind non ne può uscire in nessun modo (salvo s&t per progenitus) :-D
-Leale-
MessaggioInviato: dom 14 ago 2011, 14:06
il legacy sicuramente è più vario,
il modern sicuramente risuletrà un formato dominato da 2-3 mazzi
motivo per cui, anche alcune schok, torneranno avalere quasi nulla
a rendere vario il legacy ce il fatto che ci son tantissime carte vecchie che insieme alle nuove creanno mazzi,
magari esce una carta nuova, e un cesso vecchio diventa fortissimo,
il modern è diverso, in quanto le stegonerie bombe,son sempre di vecchie edizioni.
quindi se poi la gente preferirà il modern(che cmq ancora deve realmente nascere a livello di tornei metagame ecc)sarà per un discorso di soldi
senno non si può spiegare chi vorra giocare zoo in modern, per quale motivo non gli piace giocarlo in legacy(non parlo di risultati ma di gusto nel giocare un deck, )
non è come per t1 -legacy
dove oltre al costo delle carte, ce che anche i mazzi son di piu ed il gioco è piu vario.
in legacy-modern ce solo la componente costo delle carte
anche se magari si proxerà una shock :-D allora si che si dovrà smettere di giocare :-D
MessaggioInviato: dom 14 ago 2011, 14:18
concordo pienamente con subzero. Il bello del legacy è proprio questo, nn c'è un tier1 che sovrasta tutti i mazzi come in t2, non ci sono 3 tipi di mazzi che vincono come t1(gush,tezz,stax), i mazzi non girano come in esteso. Il legacy è diverso. Sì, ci saranno i soliti tier1 che occupano una parte buona del field e che vanno a periodi(merfolk,hive mind,landeed,TA) pero ci sono tanti anzi troppi mazzi competitivi che una side di 15 carte nn basta xd.
Modern è identico al legacy... ci sono miliardi di mazzi in modern tutti ugualmente competitivi , solo che ci sono meno carte disponibili. Non potete dire che Zoo adesso è il mazzo da temere... si vedrà fra un par di mesi cm sarà questo modern, che sono sicuro, sostituirà l'esteso nelle stagioni dei ptq.
aPZ7W44y2k
